Yes, hoping valve seats are ok…
Need to learn again what would determine a bad valve seat.
Anyway, excuse me, I’m an idiot.
It wasn’t at TDC…it was late
Nevertheless, each cylinder rises to the same height, which is more like 3/8 to the top of the bore…so it must be correct.
Funny, i though pistons rose to the block surface.
Anyway. Gotta say…
…doing all today and looking it all over, cleaning it up, it is …perfect…
Not one bit of corrosion anywhere. The surfaces are perfect.
No cracks of any sort, nor strange signs of wear within cylinders miraculously.
No lips at block surface, nor receding liners…flawless.
Gasket in great shape too.
A couple plugged little coolant passages was all.
Everything looks and more importantly, feels pristine
No scored bores, miraculoisly…no lips or ridges, etc
May measure later for myself, however i expect nothing honestly meritng a full rebuild.
Compression was good on all cylindets but the 2 with intake valve leaks.
Leak down test revealed nothing discernable or worrying out the dipstick tube, etc.
As a note to those doing for first time.
Don’t touch anything. Any debri that may be within cylinders, etc.
Attach a rubber tube to your shop vac and suck it all up.
Then use grease to seal periphery of piston tops to guard against anything getting in there.
Smear the bore walls too.
Clean the block surface…i used rags and electrical contact spray, and duct tape the surface.
Stuff wrags at front where chains are and cover with garbahe pag piece and tape as well.
Anyway, i couldn’t be more pleased.
No ridges at bore tops at block surface, no recessions caused by sleeves possibly dropping, etc…just perfect.
Many of the studs move within their holes which is a good sign.
But they will require some careful attention and massaging to remove.
Funds are light for head work.
Everything appears normal, but i of course need time with it.
Anyway, with what i do have i will restore engine bay, sand, repaint, detail, replace and properly update hoses and wiring, prepare them for those hot temps, etc…replace studs of course…
Clean all meticulously.
…then figure out the cylinder head.
Springs and valve seals are certain.
De-carbon everything and polish all.
Should guide clearances be ok, I’m debating whether to upgrade to bronze alloy?
Anyway, yes, very pleased and relieved.
Could not have hoped for better.
Kind regards
![P_20180708_203913|281x500]
As a note, those coolant passages were cleaned out and surface cleaned more prior to sealing.
That was only some carbon buildup of some sort around studs at block surface.
Cleaned right up!
After cleaning debris off pistons, oiling, etc…i hand cranked allowing a full cycle of each to inspect and measure cylinder bores. No scoring and no ovals…all within spec remarkably showing hardly any wear differentials. Amazing.
