Wondering what problems this split in the tubing would cause?
That is part of the purge system for the gas tank if I’m correct. Any parts store will sell a barbed brass fitting to replace that line. Is that cracked barb a part of the entire valve or is it separate? My xjs is actually running a valve from a Mitsubishi. It totally works. I can get you the part number in the morning if you’d like.
Cool - thanks! Lemme get it apart and see where things are from there.
