What type of signal or outputs should I expect to see
on wires that come from the speedometer sensor
(part DBC2632) mounted on the rear differential ,
when it’s working correctly?
I need this info to help troubleshoot and diagnose the speedometer
sensor on my '93 XJ-S convertible with the 4.0L six,
As a diagnostic for a dead speedo, I want to try reading a signal directly from the transducer, or simulating an input signal from the transducer into the speed sensor unit mounted in the boot, but to conduct either of these diagnostics, I need to know more about the output that is expected from the speed sensor transducer.
My speedometer has no readings, (I know… that’s the FIRST time you’ve heard this complaint!) and I’ve verified that my odometer, cruise control and the speed functions of my trip computer aren’t working either.
This means that problem is probably:
In the speed transducer that goes into the differential, or the wiring from it
In the speed unit mounted in the left side of the boot.
(less likely) in the wiring going from the speed unit, to the speedometer, ECU and trip computer.
I’ve read every thread I can find on Speedo’s, but I didn’t find the answer to this question.
The closest I found was this very interesting thread:
But it’s speculative and not conclusive, so I thought I’d ask the forum for help.
My hope is that collectively we can figure this out so that rather than partially diagnosing speedo problems, and then taking a leap of faith by guessing which part or parts are malfunctioning, – and risking being wrong – and I can actually test each component, and KNOW which one is bad.
I have ordered a used speed unit from the UK, so I can swap that out when it comes, but I’d really like to do a better diagnostic.
Here’s what was proposed in the earlier thread along with a drawing of a possible schematic or logical diagram.
(9/13 -updated my post for better formatting and better readability.)
