Hi, all my windows get steamed up every time when teh AC is off… Does any body have the same problem, if i turn the blower completly off it is ok and also when the AC is on.
But when the blower is on and ac is off all windows get steamed up a lot.
any idea what to do? Thanjs for help.
regards J
You do realize that Jaguar issued many TSBs for your car.
I uploaded THOUSANDS to several websites on the interweb so a search should yield results.
Here are a few for you.
JTB00183NAS1[1].pdf (142.3 KB)
XT412-02 Air Blend Door Loose.pdf (181.2 KB)
XT412-S931am2 AC System Inoperative.pdf (36.3 KB)
XT501-08 Passenger Footwell Water Leakage.pdf (51.7 KB)
tanx for help, will check ASAP
JGL
(Grahame Loader 04 X Type Estate)
December 8, 2018, 7:23pm
5
First check if the air re-circulation button is pushed.
i have checked my carpets, tehy are little wt so i will change them with rubber ones.
regards J
JGL
December 10, 2018, 1:09am
7
Don’t change them for rubber ones. Your heater core is leaking.
What should i do? Can i fix it myself?
JGL
December 12, 2018, 1:54am
9
I don’t know. The core is probably buried way under the dash. I think it would be a major project.
