My XJ6 1996 nearside window was not working found power to the motor but was overheating , replaced with a 2nd hand motor still the same problem doesen’t work from driver’s side switch either all other windows work okay so not the fuse on that side could it be the window switch something to do with the earthing ? Can anyone help.Jimbo thanks
Jimbo,
You are on the wrong list. The XJ6s discussed here are the Series I, II, and III cars. Your XJ6 is a couple of generations newer.
I believe you have what is referred to as an X300 and you should be on that list.
Paul M. Novak
1990 Series III V12 Vanden Plas
1990 XJ-S Classic Collection convertible
1987 XJ6 Vanden Plas
1984 XJ6 Vanden Plas
1969 E-Type FHC
1957 MK VIII Saloon
Ramona, CA USA
Okay thanks Paul diden’t notiice .
