is there a way to even the gaps on the chrome trim? There is an air leak at the front but all the door gaps are pretty much even? I appoligise for not checking the archives first.
David …
I don’t believe the chrome window trim is your problem. Actually from your picture unless it’s rubbing it looks pretty well aligned.
The air leak you’re experiencing is probably coming from an old door seal that’s lost it’s flexibility.
Item #2 in the above diagram. After market seals are readily available.
The trim in the back is almost rubbing, and I can see thru the gap in front, 1/8 inch forward and I am good but I can’t see anyway to do that. I just noticed a loose torx screw on the front of the door that may be what holds it in place, I am hoping that may be the culprit.
