When opening the doors ,windows drop down but go right back up when you release the handle. Causing the window to be outside of top when closed. Tried 5 second reset,bought new battery, reset again. What next? p.s. started with passenger door now both do it.
Sounds like the micro switches in the lock mechanism sticking. You will need to remove the door cards to get to them. Try a squirt of silicon grease to try and free them up.
Try to reset the window position. Drop the window and hold the switch until a faint click is heard then raise the window and hold until the click is heard.
Have tried 5 second hold several times,bought new battery, it seems when I pull door handle window retracts as normal but goes back up as soon as handle is released not waiting for door to close
