Windscreen crank handle screw/ fitting
Hi, I have realised that I do not have the screw or bolt or whatever it is called that holds the crank handle on for the windscreen opener, the part that goes through the handle and holds the crank on over the splined shaft, Tried the usual places but nobody seems to have one, anybody got a spare or a lead
Thanks
Mike
I’m sure it’s just a standard 2BA raised c’sunk chrome steel set screw. If I get a chance, I’ll check later today. These screws might not be available via a Mk IV or V source but a similar one may have been used in later models somewhere around the dash.
Also, chrome is often replaced by polished st. stl. these days. Check Classic Fasteners in Welland, Sth Australia. They have this size in various lengths, but I’ll try to confirm the measurement today.
Peter
Yes, as stated, 2BA x 1/2".
Thanks Pete
For some reason I thought it was a special fastener
Mike
