I have this Wiper motor but it has an extra electrical plug that I have not seen before, I would like to know the extra plugs purpose and I would like to ad a photo if I knew how on this forum.
Welcome Bill.
A photo would be useful.
It’s the Upload button on the top row of the Reply window.
all the best
Or bottom right if you are on an iPad
not extra, one for speeds and other for park
Is there a problem with the wipers, Bill…?
The motor is controlled by the stalk switch - which is the usual source of problems…
Frank
xj6 85 Sov Europe (UK/NZ)
Hi Frank
No there is not a problem with it that I know of, I am fitting this wiper into another different sort of car.
So I just would like to know what the other electric plug is for.
Regards
Bill
Hi Tom
Ok thank you
It is just that I have used other Jaguar wipers but never one with a second electrical plug
Regards
Bill
what model is the motor from & do you have the diagram for it
I don’t know and no I don’t have a diagram, I bought it on the net.
are you doing the hot rod transplant? looks like a motor from an XJ6 series 2
Just to expand, Bill - the Jaguar stalk switch, when turned to ‘off’, reverse the polarity to the motor - reversing its direction. This reversal is mecessary for the self park to work - and, depending on the your set-up; the extra connector may relate to that…?
Never saw that extra connector on the ‘our’ Jaguars, nor does it appear in the wiper wiring diagrams. Are you sure it relates to the wipers?
Frank
frank, i have that motor in my xj6 s2
Hi Frank
Thank you for explaining the stalk switch , that will come in useful I think.
Well that’s why I asked the question on the extra plug as I had never seen one before either.
It is part of the wiper motor so I can only presume it has to do with the wiper somehow.
I might have to clean of the fabric covering and check the wire colours, maybe that will tell me something.
Thank you
Bill
Hi Tom
Yes I am using the wiper motor into a 46 Ford Convertible.
I had a XJ6 series 2 and the wiper did not have extra plug on it.
Thank you
Bill
well looks like you got a bonus, they were available in s 1-2& 3
