Looking at the color coding for the wires going to my 1989 XJ40’s ECU I see that the signal wire coming from the O2 sensor is labeled “INN”. This designation doesn’t show up in the color codes for the wiring.
I see that, thank you. Cross checking with my Haynes manual it does show the color code of the signal wire going into the ECU as NCA (hmm, I still wonder what INN stands for on my Jaguar shop manual ?) Perhaps ir’s some type of shielded wire ?
Ifound a link that shows that to be somesort of option can conect with a white wire I copied it to clopboard but there it sits because I can’t find clipboard on my phone, sorry, but it is also inn
Well I finally got around to digging out my engine’s ECU. Actually I was a little surprised that it was located under all the spaghetti of wires and relays and not buried behind them (if you’ve been there you’ll know what I’m talking about).
Anywho … I’ve ordered 2 (count 'em 2 with the exact same part number) used ECU’s to do some product replacement troubleshooting trying to solve my O2 sensor check engine light.
So next week when I have the replacement ECU’s in hand I’ll pull out my original ECU and plug in the replacement(s) and see what happens …
