There are two wires coming out of the rear glass on my MK2. There appears to be only one bullet connector coming from the cabin of the car. Looking at my manual it appears that one of the wires coming from the glass goes to ground and the other plugs into the cars’ pigtail, which is a hot circuit. I don’t want to blow up the demister.
as I did not know what to do with the second wire from the window. I found an auxiliary wiring diagram and Andrew is indeed correct in that the wire goes to ground. I will use a self tapping sharp piercing style screw to attach the window wire to the underside of the parcel shelf.
Holiday wishes to all.
Gerard
Picture from last years Colorado Grand which is a 1000 mile rally throughout Colorado with over 130 exotics.
