I am looking for suggestions on refinishing the wood on my MK2.
The veneer is in great condition no cracking or delaminating.
So what is the best refinish technique?
French polish
Spray lacquer
Brush lacquer
Wax
As usual there seems to be a huge variety of thoughts.
FIRST of all–don’t aggressively sand it and destroy the paper thin Vernier!! I did my MK-VIII using Verathane, it came out beautifully! and was still that way 30 years later!~
Check with Saul:
http://www.britishautowood.com/
Gerard
I had great results with micro sanding with VERY fine sand paper and multiple layers of Varathane also.
I use hardwood floor stripper, hand sand with 220 or higher, then spray a poly marine varnish, then rub back down with 1500 and pumice, and polish back (I don’t like the high shine the marine varnish gives, so I take it down just a bit).
Re-veneering is doable with a vacuum press, but if you’re just laying in a patch or fixing a bubble you can make do with clamps and felt pads.
Thanks Andrew
This is the process I used recently when I re veneered my TR6
dash in American Oak, it ended up with a slight mat finish that
suited the wood and biscuit color interior.
