I live in Utah and while driving in winter weather I have had some
severe fogging problems in bad weather. Has anyone had this problem.–
utahjag
In reply to a message from utahjag sent Thu 24 Jan 2008:
I have the same issue.
While installing an XM radio I removed the glove box and followed
the TSB on fogging.
I found the connector at the end of the inside/outside air flap was
rounded out and the actuator was not moving it. The reccomendation
for superglue in the TSB could not resolve the issue. In addition,
the flap was difficult to move, binding in its housing and stuck in
the recirculating position leading to the fogging.
I still need to drop the whole assembly and see what I can do maybe
pinning the connection. Else replacement of the flap.–
Richard Will 2002 X-Type
In reply to a message from Willr sent Thu 24 Jan 2008:
i have had fogging up of windscreen and side windows,since found
out the passenger side of the car was soaking wet carpets and mats
have lots of water on them, its going in next week to find the
leek,but prior to my leek the car stayed demisted on auto aircon–
suggs
cardiff, United Kingdom
In reply to a message from suggs sent Sat 26 Jan 2008:
Hi Suggs
Has your pollen filter been replaced recently??
It is possible it is not seated properly so not sealing.
Martyn–
Martyn 2006 X 2.5 SE
Hockley, United Kingdom
In reply to a message from martynuk sent Sun 27 Jan 2008:
Thanks for the info the car is going in next week for a check and a
cure for the water problem.SUGGS–
suggs
Hi my windows keep misting up when the A/C is off. I might have the
same problem.Have you managed to sort your issue out if so ca you
point me towards the TSB.thanks–
aky
In reply to a message from aky sent Sat 2 Feb 2008:
The connection between the servo motor and the flap controlling the
outside/inside air mix is worn out on mine. I have gotten the
blower motor out but have not gotten the flapper out.
I have disconncted the wires from the motor and placed the flapper
in outside air mode. The fogging has stopped.
A supplier said the flapper is not available alone but comes in the
assembly which can run over $500.
When I am allowed back in the garage, I will see about pulling the
flapper and rebuilding the connector. Neither the bulletin nor the
service manual I have show how to get the assembly apart.
Service bulletin can be found at:
http://www.jaguartechinfo.com
Search for XT412-02, Vehicle Fogging/Climate Control Slow To Cool
Vehicle, under Service Bulletins, Climate Control–
