Can anyone tell me the best way to remove the rear door panel
without tearing you’re finger nails out. Thanks–
garygee
In reply to a message from garygee sent Thu 27 Jul 2006:
Trim your fingernails.
Had to toss that in there…anyway, it does take a bit of force to
remove the panel, the clips are stubborn. Try using a screw driver
and gently pry on it till the clips pop out.
Hope this helps–
Speed_racer
In reply to a message from Speed_racer sent Thu 27 Jul 2006:
Hi, Thanks for the advise, does the surround around the door opener
come out prior to the door panel?–
Hope this helps
garygee
It looks like it’s all one piece…not really sure and I can’t find
a diagram anywhere as to how many pieces there are …–
Speed_racer
Thanks for all the advice, I have managed to remove the panel. It
is all 1 piece, used a flat wooden piece of wood to lever the panel
off, only broke 2 plastic studs but apart from that all is well.I
hope I can get some more studs from the dealer? Regards Gary.–
garygee
