i’m getting my jag on monday and can’t wait. it’s a 2003
model se 3.0
when I looked at it in the showroom it had a telephone
button on the steering wheel.
will I be able to use my phone/sim in the car?
i’m in sunny liverpool, uk
thanks for any response.–
sexyboy
In reply to a message from sexyboy sent Thu 15 Nov 2007:
I think it depends on whether you have the bluetooth/telephone
provisional equipment fitted. That button you refer to will
probably be the voice command system which enables handsfree voice
command to adjust the temp, change the radio channel, and
destination (if you have sat nav fitted) etc. If it has the
telephone provision fitted this will also allow you to use it for
the telephone as well.–
jimfoz
In reply to a message from jimfoz sent Fri 16 Nov 2007:
Hi!
If I may continue on the subject, I traded my Discovery for
a 2004 x-type Estate this thursday. The day before they
announced they were stopping the production. Hope I didn’t
cause it…
Anyway - my question. Does post 2003 x-types have the
bluetooth module installed or was it an option? If it was an
option, what is the easiest way to determine whether I have
it or not?
I do not have the navigation option on my car but there are
all the phone buttons. When I press the Phone Menu Button
the display says ‘‘No Phone’’ - does that mean that no phone
is paired by bluetooth or that no bluetooth module is installed?
And finally, if there is a bluetooth module installed, how
do I pair it with my phone? (I’ve tried pressing and holding
most buttons in different combinations by now and can’t find
any information in the owners manual.)
Best regards,
Richard
(a new and happy x-type owner in Sweden)–
17932
In reply to a message from 17932 sent Sat 18 Jul 2009:
Hi I have the same query, If you find the answer perhaps you
would be kind enough to let me know.
Take care John–
J.M.Sharpley
In reply to a message from monovar john sent Sun 19 Jul 2009:
Hi Guys
Make sure your phone Bluetooth option is switched on.
Switch on car ignition
Go to your Bluetooth options on your phone and ask it to search for
audio enhancements if Bluetooth is fitted to the car it should come
up with Jaguar.
Try this 1st if ok will try and find setup procedure for pairing.
Martyn–
Martyn 2006 X 2.5 SE
Hockley, United Kingdom
In reply to a message from martynuk sent Sun 19 Jul 2009:
Martyn - thanks for your reply!
I tried following your advice and if the car’s bluetooth
system is always open for pairing I guess my car lack the
option. Just to be sure, the bluetooth system does not work
like other bluetooth headsets - i.e. you have to activate
pairing somehow, for instance by pressing and holding a
button for a couple of seconds?
If the conclusion is that my car is lacking the option, does
anyone know;
a - is it extremely expensive and complicated to install the
option?
b - what components do I need to add?
Best regards,
Richard
(John - if and when I find a solution i’ll definately post
it here)–
up with Jaguar.
17932
In reply to a message from 17932 sent Mon 20 Jul 2009:
Hi Richard
Try this link to the bluetooth handbook it gives more information
on pairing.
http://www.ownerinfo.jaguar.com/extfree2viewjagprod/servlet/peachvie
wfile?t=1248270480174/index.htm
I have a feeling the bluetooth module was on option for the year of
your X but try the pairing from the Jaguar instructions and that
should confirm yes or no
Martyn–
In reply to a message from martynuk sent Wed 22 Jul 2009:
Hi Richard
The previous link may not work try this and select what you need
http://www.ownerinfo.jaguar.com/extfree2viewjagprod/index.jsp
Martyn–
on pairing.
I have the same question, I tried the procedure indicated in
manuals, but my 2003 2.5 does not connect with my Blackberry
pearl… :S–
on pairing.
elede
Queretaro, Mexico
