[x-type] There's a little tube hanging behind the passenger rear tire?
Is that plastic tube supposed to be there - is it related to the
battery?–
Humy
In reply to a message from Humy sent Mon 14 Nov 2005:
yeah I noticed that too…i have no idea what it is–
// Jaguar XJ8L [X350] // Jaguar X-Type
Brooklyn, NY, United States
In reply to a message from CARZ sent Tue 15 Nov 2005:
I queried what this was hanging down at my last service (2.0
Diesel) - They said it was a breather pipe for the fuel tank I
think?–
bc1
In reply to a message from bc1 sent Wed 16 Nov 2005:
I think it is a drain for the fuel filler. If you look, or feel,
closely below the fuel filler there is a small hole in which to
allow rainwater to drain. I have always assumed that the tubing
found behind the rear splashguard was led from this drain hole. It
would also allow water to drain when washing one’s car liberally
with hose fed water.
There was one very similar, although not as visible on an XJ Sport
(X300) I once had. The Owner’s Manual recommended that the hole be
kept clear of debris to allow easy drainage of water.–
X-Type 2.5 SE Estate
