Hi everyone, when rotating wheels is their a patten like FR to BL
etc…as my tyres are starting to wear on the front,i have the front
wheel drive model,just done 35000 KLM
Many Thanks Noel–
Noel X type SE Australia
In reply to a message from OZYINXTYPE sent Mon 5 Jan 2009:
Depends on the tires. Most tire today are meant to rotate
in only one direction so they cannot be swapped side to side.
www.tirerack.com is the bible for tire information in my
opinion. You can access their tire rotation information at
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=43&
That should answer all your tire rotation questions.–
Wild Bill
In reply to a message from Wild Bill sent Tue 6 Jan 2009:
Thanks Wild Bill, will take a look
Noel–
i did this with my last xtype and ended up having to change all 4
tyres as they all had similar wear paterns,so I am going to run my
fronts out on my new car then replace them,and will then replace
the back ones next year.SUGGS–
suggs
cardiff, United Kingdom
In reply to a message from suggs sent Tue 13 Jan 2009:
Good thinking , thanks Noel–
I did this with my last xtype and ended up having to change all 4
