I have my airbag light stuck on (and ‘‘airbag’’ on the
odometer readout). I had one sensor replaced that my Jag
guy said was an indicated fault when they read the codes,
but the light is still on.
I ordered a used control module replacement and have been
looking at the circuit board inside and the component
labeled ‘‘F1’’ has a burnt mark in the middle of it.
I believe that is a fuse on the circuit board, that is burnt.
Does anyone know what size that fuse is? Looks reasonably
easy to remove it and replace it.
Has anyone tried this?–
rhofatl
