In reply to a message from SpeedyPAL sent Fri 16 Feb 2007:
Pete,
This is an interesting idea… I did listen for leaks, but all
sounds good… Where do they normally crack, and I guess I have to
pull the heat shield to see them??
but if that is the prob, why would it run good at times, but mostly
bad?? and come and go on the same drive?? I once got abotu 20
minutes of HARD run time and it was flawless… then all of a sudden
im back to this… and sometimes its not too bad and if I ease into
the gas, or feather thru the misses, it will hook up and take off
like a rocket… Doesnt sound like a crack in the manifold, but
still worth looking into after I swap over the fuel regulator and
CPS…
Thanks!
Ron–
They are very prone to cracking on the supercharged models.
The cracks apparently allow O2 to sneak into the exhaust where it
is seen by the O2 sensors. The ECU interprets this as a lean
mixture and richens the mixture.
I had a very similar problem last summer but mine would run great
for days and then stumble all over itself. The plugs were
definitely showing very rich when it was running poorly, and very
normal when running great. I welded the cracks in both manifolds
about 5,ooo miles ago. The problem has not come back, yet!
Good Luck, Pete
eyeinstine
North Hanover Twp/NJ, United States
