have a '98 Vanden Plas that beeps on startup 5 times, every
minute, for 3-4 minutes. Goes away and then sometimes comes
back during the drive. Already tried plugging in both front
seat belts. Tone sounds like it is coming from the middle of
the dash. Any ideas?–
puchscooter
In reply to a message from puchscooter sent Wed 26 May 2010:
Next time it happens, look at the display on your head unit. It
may be the ‘‘clean aerial’’ reminder.–
puchscooter
Gary 4.0V8 http://www.jag-lovers.org/v.htm?1253292792
London, United Kingdom
Someone might have planted one of these.
83 XJ6 / 97 XJ6
Denton, TX, United States
Look at the instruments when you start the car and see if
the Airbag telltale lights up. If you don’t see that lamp,
you are probably hearing the Airbag Module. [also called a
Single Point Sensor] It is designed to sound off with beeps
if the warning lamp fails. It can’t warn of an Airbag
failure with a burned out bulb, so it uses that method to
get attention.–
Steve, '95 XJR
Indianapolis, Indiana, United States
