''I just went through this with my 1995 XJS V12, it could not
be easier. There is no programming involved in getting the
daytime running lamps working - you just need a few parts
from your local dealer:
2 x DAC-7687 Relay
1 x DAC-7686 Relay
1 x LHC-3450AA Wiring Harness
All the cars left the factory pre-wired for daytime running
lamps, but the USA bound cars were shipped without these
final few bits. In the engine bay, along the top of the
inner left wing, you will find wiring ends to plug the new
harness into, and a bracket just waiting for the relays. If
you go really slow, it’s a five minute job to install.’’
Is this applicable to my 1996 XJ12?
The 1996 MY XJ12 is OBD II, whereas the XJS 6.0L is OBDI…
-Chris–
Chris Los 1989 V12 Vanden Plas, 1996 XJ12
Hi thetopdogg!
I’m a new member and would like to DISABLE the DRL (1996 X330 Vanden Plas, first delivered in Canada) - unfortunately the official Jaguar Trader was not able to do… So could you be so kind and send me an explanation (in details) how to reinstall the relays? Please contact by harol@mein.gmx
Thank you.
regards HA
You might try what I did to get them. I replaced the body processor module from a Canadian donar car that also gave me front headlight washers. Everything worked the same
Hello Phil,
sorry for not responding until now…
I actually have a second BPM - but it’s from a GERMAN vehicle (my current vehicle is from Canada). I’m worried that the replacement might disrupt all the other control units.
Are you sure that an exchange is possible without any problems? (Jaguar couldn’t give me any information on this…)
Best regards
Oliver
Sorry for my questionable explanation - my X330 switches on the complete entire vehicle lighting when the ignition is switched on (the light switch only switches on the instrument lighting and decides whether the parking light is on while the ignition is switched off). To substitute all single lamp plugs with a resistor means a lot of work - so what solution/cognition might be expected?
