I’m going to have to bite the bullet and try it sooner or later
And so I did. The sequence, Neil, was exactly as you advised. But here’s where it gets interesting for people trying this in the future: the only reason I knew the sequence was working was because I already had a known-good remote. The first attempt I couldn’t get either remote to work, because I was assuming the ‘new’ one was working properly.
I pulled the new one apart and spent a while cleaning the PCB and the backs of the buttons with contact cleaner on a cotton bud. I made several cotton buds go completely black. On the the third attempt the car recognised the new remote but afterwards I could only get one of the four buttons to work properly (the boot opener, as it happens).
More cleaning and determined pushing and it now works - just. The thing for others in this position to bear in mind is that, if you don’t have a known good remote in hand, you won’t necessarily be able to be sure you got the learning sequence right - and you’ll tend to assume you haven’t. For the sake of the record here is exactly what I did:
(1) Put the key in the ignition, don’t turn it
(2) Wait for the seat and steering wheel to finish their little dance
(3) Pull the indicator stalk towards you so the headlights come on, and hold
(4) Turn the key one click
(5) release the indicator stalk then immediately flash the headlights four times (at roughly 1/2 - 1 second intervals; not too quickly, not too slowly)
(6) J gate light comes on and then goes out
(7) Press either the lock or the unlock button on a remote. J gate light blinks to acknowledge
(8) Repeat on each remote
(9) If you have less than five remotes(!) press the button on the last remote more than once, until you’ve made a total of five blinks happen on the J gate light.
(10) turn key back to position 0
On my 1998/99 UK Sovereign there were NO beeps/chirps or other sounds.
As predicted, my first attempt resulted in neither remote working. So I put the ‘new’ remote in my pocket and started again with just the original, pressing ‘lock’ five times. This worked fine and the remote came back to life. I repeated the process just to be sure, so I knew the car was doing its thing correctly and that I just had to get the other remote to work.
After that, I thought I should also try the spare key I got with the car. It did start the car - but I got the dreaded ‘restricted performance’ message. Panicking only slightly, I reversed the car out of the garage, left it running for a few minutes and then shut it off and restarted with the other key. It came up fine… and then when I went back to the second key that was fine too. I’m thinking that, with my feeble battery (see other posts), not having used the car for two days and then messing with the remotes/lights/locks etc. the charge state was borderline and triggered a spurious status.
I now have two keys, with two remotes, and all working. If I find out what relationship if any there is between these and the seat memories I’ll tell you all about it. Now, if I had the valet key I’d be really happy…
JustinOn 23 Oct 2012, at 12:26, Justin Hill wrote:
Justin Hill, Surrey UK
Jaguar XJ8 4.0 Sovereign LWB 10/98 99MY vin 858319
jhill@cka-net .com
