Yesterday I played the radio and cassette just fine. Today
NOTHING. No antenna up, no radio power on, checked fuse #6
10amp in boot area. Strange thing is that there is a low
audible 2 tone chime noise coming from inside the radio unit
itself. I pulled the fuse and the noise still sounds. Is there
another fuse? Any other advise before I just pull this unit
out?? Also the CD changer kept cycling even after pulling the
cartridge out. I disconnected this as to not drain the
battery. Thanks.
I have had this cat for only 2 weeks and already the problems
are piling up. Goes in next week for rear drive shaft seal
leak. OUCH.–
Miklos
Honesdale,Pa, United States
In reply to a message from kitty plas sent Wed 18 Apr 2012:
update: pulled positive battery wire, left off for several
mins, put positive wire back on battery, radio now works fine
and low audible chime stopped.–
1996 Vanden Plas 91K
