When I search for a replacement I find the part number EBC 9658. Does it matter whether you use the longer type filter or the shorter one? Seems there was a change along the way.
Thanks, Tim– nbku84z –Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]–
In reply to a message from nbku84z sent Sat 7 Jan 2006:
they both work as long as you can screw it on. pajtas– jaguarjoe 54 XK 120 rdstr 1961 MKIX 94 XJ6 –Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]– –Support Jag-lovers - Donate at http://www.jag-lovers.org/donate04.php –
