Del,
No, if you had seen those XJ40s at the test facility after sitting out in
the Arizona sun for 3-4 years, you’d be too embarrassed to drive the car.
They looked like something from a car wax ad.
Don’t forget that unless you owned your car from new, there’s no telling
what the PO did. I foolishly used Greased Lightning to clean a set of dirty
wheels on another car. It immediately turned the clearcoat cloudy. Even if
you did own your car since new, there’s also the possibility that you
encountered some environmental contaminant. A local club member recharged a
battery near his newly repainted (base/clear) XK150. Being diligent, he
removed the caps on the battery. Conditions were just right and the acid
vapors wafted over his car and etched his clearcoat.
You wash and polish your car every time it goes out? every weekend? That may
be the problem. Most polishes have a small amount of abrasives to even out
imperfections in the paint. I scanned through a couple forums and the
consensus is that at most, you’d need to polish your car once a month, but
most do it every two to three.
Check this thread from the AudiWorld Auto Detailing Forum
http://forums.audiworld.com/detail/msgs/7189.phtml.
This snippet was from a detailing professional.------------------------------
You use a polish/cleaner by hand. Yes, you are removing scratches,
oxidation, old wax, etc. Thus, you are removing a very small layer of
paint/clearcoat.
The clearcoat is a top coat. Over time, you will run out. Of course, you
accelerate this process when you use a buffer.
One other note: Not all polishes/cleaners are created equal. Some are more
abrasive than others. This is why you may need a small number of products to
remove the imperfections.
Follow the directions on the bottle. Most state that you should use once or
twice a year.
“Mark 1” Mark Stephenson
'52 XK120 S673129, '59 Mk1, '84,'85,'86 &'95 XJ6
-----Original Message-----
From: owner-x300@jag-lovers.org [mailto:owner-x300@jag-lovers.org] On Behalf
Of deljagman
Sent: 05/30/2006 6:40 AM
To: x300@jag-lovers.org
Subject: Re: [x300] paint problem? has anybody had their paint turn cloudy?
In reply to a message from uncle sent Tue 30 May 2006:
coudnt agre more looking after youre paint work is a must but there
are some of us who look after our car to a very high standerd and
still the overall condition of the paint/clearcoat still looks very
poor compared to other manufactures .my car is garaged everyday
(exept weekends) washed and polished every time it goes out but if
anybodyelse was to look at it they could think its been sitting in
the dessert for 10 years its that bad!!!
Dirt and other products of the environment, plus the sun are harsh
on all paint jobs. If the PO’s did not wash it frequently, then you
deljagman
