In reply to a message from Alex Kitney sent Wed 13 Jun 2007:
Have done much research today…
ALL XJ8 models after VIN 878274 (2000 model year vehicles) were
factory filled with Havoline XLC Extended Life Coolant,
specification WSS-M-97B44D This is the bright orange/pink colour.
WSS-M-97B44D spec coolant is even bettered by WSS-M-97B44D standard
(both are orange/pink in colour). Both these types of coolant are
chemically the same as DEX-Cool and any other coolants of this
colour.
Yes some of you are sort of right in the forum. It is desirable NOT
to mix different colours of coolant, and I stand to be corrected
(after being told ‘bull’ by some nerd at my local dealer). It
should not harm your engine if you did however, but the most harm
will be done to the protecting properties of the new coolant that
you fill the car with.
The ‘Yellow’ coolant was Jaguar D542, this is chemically the same
as Dex G-05 and any other coolant you find that is bright yellow.
The XJ8 was factory filled with this prior to VIN 878274 (prior to
2000 model year cars).
Now this where we can all debate the subject for ever and ever. Yes
you can stick with the yellow coolant, but there have been problems
with this coolant. Jaguar Technical Bulletin 303-11 dated 09/2001
says ‘ON SOME VEHICLES WITHIN THE ABOVE VIN RANGES,(XJ8 812256-
878274), THE ANTIFREEZE SOLUTION SYSTEM MAY DETERIORATE, CAUSING
REDUCED CIRCULATION THROUGH THE HEATER CORE, RESULTING IN POOR
HEATER PERFORMANCE’ This bulletin then goes on to describe flushing
the cooling system and refilling with Havoline XLC Extended Life
Coolant. This type of coolant is newer technology and can only be
an improvement. It worries me when the Jag bulletin mentions the
fact that the Yelow G-05 coolant can deteriorate, to this end I
want something better than G-05!
My money is on the newer technology. I know some of you have read
on the net and in the motoring press bad negative/publicity
regarding the Orange XLC type coolant. It seems as with anything
these days there will always be an exception to the rule and it may
appear that some cars do not like the stuff. This I think is an all
too easy judgement call to make in blaming the coolant… when
other studies have shown that there were other factors involved
with these specific cars (sludge, pre existing corrosion etc). The
bench studies pre the introduction of Dex-Cool type coolants to the
market was 100,000,000 miles in ranging internal combustion engines.
I have included this link to Valvoline which gives the specs for
Dex-Cool, G-05 and Original Green
http://www.valvoline.com/zerex/pdf/Zerex_CoolantChart.pdf?
coaid=1B5D1AEA1AFC
I hope this clears things up! I got mighty confused by the colours,
specs, forum opinions etc. That is why I embarked on this research
today.
I have now drained and flushed my XJ8 and have refilled with the
newer technology coolant. This being the orange/pink coolant that
Jaguar have used as standard since VIN 878274.
Regards to all–
Alex Kitney
Calvert Green, Buckinghamshire, United Kingdom
