In reply to a message from XJeff sent Wed 29 Jan 2003:
Jeff, glad to hear everything worked out.
I was curious to find out what the TSB said for the plastic vs
metal rivets, and I posted it below. Mine are definitely of the
plastic variety.
Sunny
Front Undertray - Loose
13-41
DATE 6/99
MODEL
1995-97 MY Sedan Range
VIN
7200001-812255
Partly Detached Mountings - Front Undertray - Repair Method
ISSUE:
On some 1995-97 MY Sedan Range vehicles, the undertray may become
partly detached from the bumper cover. If the rivet has pulled
cleanly away from one or more of the tangs on the bumper cover
moulding, the rivet can be drilled out and replaced by a spring
clip and bolt.
It is not necessary to replace the front bumper cover and undertray
assembly if the tangs are intact, even if split where a rivet has
pulled away through the edge of the material.
The same method should also be used should it be necessary to
install a new undertray to the existing bumper cover.
ACTION:
In case of a customer complaint a loose undertray on a 1995-97 MY
Sedan Range vehicle, perform the following procedure:
Raise the vehicle to a convenient working height.
Drill out any displaced rivet.
Place a spring nut over the tip of the tang on the bumper cover.
Align the undertray with the tang, and secure in place with a
Torx-head bolt. It will be necessary to keep the spring clip from
rotating as the bolt is tightened, and to fully align the spring
nut to the tang.
Warning: Do not hold the spring nut with the fingers while
tightening the bolt. Rotation of the thin metal could cause
personal injury - use pliers to prevent rotation.
PARTS INFORMATION:
DESCRIPTION PART NUMBER QTY
Spring nut - 6 mm XR8 7652 10
Torx screw - 6 mm XR8 2059 10
WARRANTY INFORMATION:
FAULT R.0. TIME
CODE NUMBER DESCRIPTION ALLOWANCE
VJ DB 02 76.93.72 Replace all undertray fasteners 0.35
hrs.–
Also needed to replace right side driving light (thanks for the
tips Sunny). My undertray was secured by aluminum rivets. These
were not normal pop rivets and had a black finish. I had to drill
to remove. Is this normal ? Most descriptions on this list have
indicated that plastic rivets are the norm. I was aprehensive about
taking a drill to the baby - to say the least. Per suggestion on
the list, I replaced with clip on speed nuts from my local hardware
store and #10 screws. Very practical solution. I will need to cover
their shiny heads with a bit of black paint. From a low angle front
view, the screw heads look like a gap-toothed grin.
Sunny Garofalo, '97 XJ6 Anthracite, '76 XJ12L Sable
Sherman Oaks, CA, United States
