In reply to a message from sogood sent Sat 7 Feb 2015:
Hi again. I took a look see at my donor car (my daily driver
doesn’t have a sunroof!) and by torchlight, I managed to
ascertain a few things.
Firstly, just so that we are singing from the same hymn
sheet, the black connector on mine has 8 wires in total, in
two rows of four. Depending upon how you look at it, the
colour coding would be as follows, assuming you’re looking
into the open end of the connector, with the BLACK wire in
the top left hand corner.
So, on the top,it’s BLACK, RED/GREY, GREEN/RED, WHITE/BROWN
then below, BROWN/WHITE, RED/WHITE.ORANGE/GREEN,ORANGE/WHITE
Some of the colours are hard to distinguish, especially by
torchlight, but these are close!
I don’t have any power going to the connector, but I could
identify the earths, of which there were two. BLACK and
RED/WHITE.
According to the wiring diagram I could only identify two
live feeds, which were described as GR which is power in to
the Map Lights and RLG which is power in to the Interior Lights.
Maybe this helps, but it’s a minefield. For what it’s worth,
my donor car is a 97 Sovereign with European Spec.
As mentioned, any further details of what you’re trying to
do might help.–
sogood
Kerry, Ireland
