Hi thanks for the help with my tow bar.
i have just tried to replace broken areil mast when I took
the old one out the nylon gear was missing ihave now fitted
the new one but it does not retract fully I would just like
to no if this is correct or if I have made a mistake.–
srh33048
In reply to a message from srh33048 sent Sun 16 Jan 2005:
hi hope you sorted your tow bar, sounds like you understood
it all.The aerial,it should go right down flush, it is posable
that it is switching off to soon, this is set up inside the gear
and mast push/pull,it is a long time ago when I last work on
one and it was the electronic parts that I replaced ie switching
transitors, open it up and try again.best of luck bobbyrob.–
BobbyRob
