Hey all, does anyone have any experience of changing these
items at all? Cheers, Richard–
Mechaniac
Lancaster, United Kingdom
In reply to a message from Mechaniac sent Sat 14 Dec 2013:
Here in the US, we can get a rebuilt rack for about $300, so I lost
interest in rebuilding mine myself!–
Ross - 89 XJS, 99 XJR, 02 XJ8, 12 XF-R
Hi Richard,
Looking at the parts diagram:
http://tinyurl.com/X300SteeringRack
The X300 rack appears to be very similar to the one on our
'93 XJ40 and identical to the one used on some of the
'94XJ40s. The rack mounts without traditional rubber
bushes. The rack bolts to the front subframe with
metal-to-metal mounting points.
However, there are rubber vibration-absorbing joints between
the rack mounting brackets and the rack body. I have never
heard that replacements were available either from Jaguar or
aftermarket sources. I do remember that at least one member
used large U-bolts beside the rack brackets to eliminate
excessive movement that develops in the rubber junctions
with age.
What exactly are your symptoms?
Don–
Don B : '04 XJR '93 XJ40 VDP ex-'88 XJ40 Sovereign
Franklin, TN, United States
There is an XJR kit of split plastic spacers to take up slack in the rubber
mounting bushes with no dismantling at all - it transformed my XJ40 for the
sake of 5 minutes under the car. SPC1059 seems to be the part number. One
was sold here and there is a photo:
http://www.ebay.co.uk/itm/XJR-XJ40-X300-Jaguar-OE-Steering-Rack-bush-Repair-
Kit-spc1059-/151176154727
Easy enough to make up a pair from nylon tube or sheet, I’d imagine.-----Original Message-----
From: owner-x300@jag-lovers.org [mailto:owner-x300@jag-lovers.org] On Behalf
Of Don B
Sent: 16 December 2013 02:33
To: x300@jag-lovers.org
Subject: Re: [x300] x300 steering rack bushes…
Hi Richard,
'93 XJ40 and identical to the one used on some of the '94XJ40s. The rack
mounts without traditional rubber bushes. The rack bolts to the front
subframe with metal-to-metal mounting points.
However, there are rubber vibration-absorbing joints between the rack
mounting brackets and the rack body. I have never heard that replacements
were available either from Jaguar or aftermarket sources. I do remember
that at least one member used large U-bolts beside the rack brackets to
eliminate excessive movement that develops in the rubber junctions with age.
Don
Hey all, does anyone have any experience of changing these items at
Don B : '04 XJR '93 XJ40 VDP ex-'88 XJ40 Sovereign Franklin, TN, United
States --Posted using Jag-lovers JagFORUM [forums.jag-lovers.org]–
In fact here is one for sale:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=151189166673-----Original Message-----
Of Don B
Hi Richard,
Don
In reply to a message from Don B sent Sun 15 Dec 2013:
U bolts sounds crude but there was a white nylon shim (and
wire?) kit from Jag that slipped each side of the built-in
rubber mounts to reduce lateral play and firm up the
steering for sports models. It can be used to firm up a
soggy rack on touring models too, which is what I did
although I only fitted one of the shims. The built-in
X300/X308 rubber mounts are not user chamgeable AFAIK,
which leaves shimming or a rebuilt rack…
Pete–
1E75339 66 D, 885958 62 FHC,1R27190 70 FHC, 1R28009 70 FHC
Gaithersburg, Maryland, United States
In reply to a message from PeterCrespin sent Mon 16 Dec 2013:
I assumed Richard was referring to the bushings inside the rack
ends.
He didn’t say which car he was working on, but the X-308 has a
shaped rubber bushing between the mount bracket and the rack. The
X-300 is different, as I recall, and uses a T shaped bushing. I bet
you could cross the dimensions and buy something from
polybushings.com ‘‘T bushes’’ section and shim side to side with
washers. I stiffened up my XJS steering a good bit by sliding
(hammering???) some flat washers beside the rubber bushings.–
In reply to a message from Jerry Jones sent Mon 16 Dec 2013:
Jerry,
That’s a tremendous tip! I think I will try to make up a
pair for our XJ40. From looking at the photo, I assume the
split ring ‘‘bends’’ apart to slip over the rack. A couple of
questions come to mind:
Do the rings fit on the inside of each mounting bracket
or on the outer side closer to the tie rod boots? -
Can you estimate how thick the rings are? I may try to
find a suitable sheet of tough-but-flexible plastic.
I searched the part number SPC1059 at jaguarclassicparts.com
and several Jag parts websites, but came up with no hits. I
wonder if the seller got the part number wrong?
Thanks again for this great tip!
Don–
It was along time ago and a garage fitted them for me so my memory is hazy.
I think that, in your position, I’d crawl under it and measure the gaps to
fill. At a guess, 2-3mm thick.-----Original Message-----
Of Don B
Sent: 16 December 2013 14:56
Subject: RE: [x300] x300 steering rack bushes…
Jerry,
That’s a tremendous tip! I think I will try to make up a pair for our XJ40.
From looking at the photo, I assume the split ring ‘‘bends’’ apart to slip
over the rack. A couple of questions come to mind:
Do the rings fit on the inside of each mounting bracket or on the outer
Can you estimate how thick the rings are? I may try to find a suitable
I searched the part number SPC1059 at jaguarclassicparts.com and several Jag
parts websites, but came up with no hits. I wonder if the seller got the
part number wrong?
Don
rubber mounting bushes with no dismantling at all - it transformed my
XJ40 for the sake of 5 minutes under the car. SPC1059 seems to be the
part number. One was sold here and there is a photo:
Hi all, many many thanks for your help with this… The
symptoms are just generally soggy steering which makes the
car very unpleasant to drive at high speed, as you are
constantly having to ‘‘manage’’ the steering, slightest camber
changes, the act of crossing the white lines on the
motorway can be entertaining… you steer into the lane
change and the car sort of ‘‘floppops’’ over the line…
Everything else has been renewed- all ball-joints,
suspension rubbers etc etc and the tracking (all 4 wheels)
carried out by Jaguar last year. There seems to be a lot of
movement on the rack. Saw the split nylon rings on e-bay and
have ordered a pair. I will take the dimensions of these and
then turn a few more up on my lathe if these help… we have
3 Jaguar x300s in the family! I shall stick the dimensions
on here…
The car had a re-con rack fitted just before I bought
it 4 years ago but I understand that when you receive a
‘‘re-conditioned rack’’, these bushes may not have been
changed… Thing is, if these spacer rings take out all the
movement, does this expose the actual mounting screws to
more shock? I think they are only 8mm screws!!–
Mechaniac
In reply to a message from Mechaniac sent Mon 16 Dec 2013:
Mechaniac,
I for one will be anxious for your post with the dimensions
of the split nylon rings when you receive them. With
postage to the U.S. the price is a bit of a deterrent. I
did finally find a list of XJR-S part numbers that showed
that part, but the list stated that none of those parts are
officially available from Jaguar separately. Thanks for
your willingness to share the dimensions with the rest of us!
You mention that all the suspension rubbers have been
renewed. Did that include the front subframe ‘‘Vee mounts’’
and rear pivot bushes? When those wear they allow a lot of
movement in the front subframe to which the steering rack is
attached. Replacing those and the lower control arm bushes
tightened up our front steering quite a bit, but our rebuilt
rack also has some excess movement in those mounting bracket
bushes that I’d like to eliminate.
I suspect that the purpose of those bushes is not to protect
the rack mounting screws so much as to reduce perceived
vibration and harshness in the steering wheel.
Cheers,
Don–
on here…
In reply to a message from Don B sent Mon 16 Dec 2013:
Hiya Don… yes, all of these bushes have been replaced, each
making a little difference every time, but I feel that these
gains are being lost through the deterioration of the rack
bushes… Believe me, the actual purchase price is a bit of a
deterrent here, (Over �35 for a couple of nylon washers!! )
and I would not pay it were I not so fed up with the way
this issue totally takes away the enjoyment of driving this
otherwise lovely car at speed… I could try and experiment
with different thicknesses etc but just thought better to
pay the money and get the correct fitting stuff to begin
with… Hopefully will be here in the next couple of days so
shall post the details as soon as I have them, fantastic to
have an opportunity to be able to contribute a little
something back to the members of this site, who in the past
have been so helpful, and have saved me that �35 and very
much more in the past because of their experience :)–
Mechaniac
In reply to a message from Mechaniac sent Tue 17 Dec 2013:
Mechaniac,
Just to be clear, I was not criticizing you for purchashing
those washers. If I had three cars they would fit, or even
two, I would count them a bargain. But the �35 plus
overseas shipping made me think twice.
Looking forward to what you learn about the bushes when they
arrive.
Cheers,
Don–
In reply to a message from Don B sent Tue 17 Dec 2013:
Ooo, no, I didn’t for moment think that you were And if they
help cure the problem, then to my mind, they’re gold, not
nylon :)–
Mechaniac
Your description sounds identical to excess toe-out. I’d
double check the fronts are still aligned with some toe-
in. A knock or a change of some other bush can put things
out of whack.
Pete–
In reply to a message from PeterCrespin sent Tue 17 Dec 2013:
Thanks Peter, I have the spacers en-route and will see how
they go, but yes, probably worth having the track checked as
well, I have clipped a curb or two, it’s worth saying :)–
Mechaniac
Just to say Dom, I haven’t forgotten about these sizes,
still waiting for the spacers to arrive!–
arrive.
Mechaniac
In reply to a message from Mechaniac sent Thu 26 Dec 2013:
Thanks for the update, Richard! I was just noticing the
ebay listing earlier today and wondering if you’d received
them yet.
Merry Christmas!
Don–
In reply to a message from Don B sent Thu 26 Dec 2013:
Merry Christmas to you too, Don, as soon as I have them,
you’ll know about it! Just our postal service seems to go to
pot at this time of year… Not helped by the fact that
these items are being sent to my works address and we are
closed for Christmas…–
Mechaniac
Still waiting Don!!! Grrrr :)–
Mechaniac
