[x300] X300 XJR Supercharged TPS help!
Hi
Does anyone have any words of advice for removing the TPS on the
supercharged AJ16 engine? I need to know if there is a way of
getting it out without removing all the charge cooler etc etc–
Sovereign 4.0
Sussex, United Kingdom
In reply to a message from Aaron_x300 sent Mon 27 Jan 2014:
This is the way I have done this on two cars and only
requires a top up of coolant and inlet manifold gasket
replaced and you can clean up the TB and the same time.
http://tinyurl.com/mkeojoh--
95 XJR6, 94 XJS 6.0 coupe, 04 XK8 ,99 Ka
Croydon , SURREY, United Kingdom
