Hello;
My 1996 XJ12 is fully imported, licensed and on the road.
It took 6 months and quite a bit of searching to find the 4
solar wheels, the X308 HID headlights and bumpers and the
grille (being painted, not yet installed).
The only mechanical issue I am having is the windshield
wiper doesn’t work on the ‘‘1’’ setting. It works on
‘‘intermittent’’ and ‘‘2’’ (high speed) but putting it to ‘‘1’’ it
parks.
Is this a matter of replacing the stalk, or an ECU or the motor?
Thanks,
Chris–
Chris Los 1989 V12 Vanden Plas, 1996 XJ12
In reply to a message from thetopdogg sent Wed 2 Jun 2010:
Hi Chris,
Had a look at the wiring diagram. Could be that the
fast/slow wipe relay is not working. Try swapping with another
relay. Could also be the stalk earth contact for ‘‘slow’’ not making
contact. Try relay first.
Mike–
Mike Jones, 1995 X300 3.2 Litre 89000miles
Worthing, United Kingdom
In reply to a message from Mick83 sent Wed 2 Jun 2010:
I know this is a bit silly… but do you have auto wipers??
If so maybe they are not working because they are not detecting
rain.
Mine are in Auto when in the I positon with the tab slid to Auto
and will not move unless rain is detected. Slide the tab out of
auto and they work like normal intermittent wipers.
