Has any one found a garage who would do this? I’m getting a rattling from the rear and suspect it’s these. I know it’s possible, but the garages I’ve approached say they would only replace the whole shock absorbers, with some vague excuses that it can’t be done, but I think they just can’t be arsed.
I replace them BUT it is nearly impossible without removing the damper so the upper isolators AND the spring isolator should be replaced also since it will be apart.
A ‘kit’ of bushing ‘cups’ and a press or heavy ‘C’ type screw press will be needed to get the damper lower ‘spherical-joints’ out and new in.
This will also work if the sizes are correct.
https://www.amazon.com/Universal-Sleeve-Remove-Install-Bearings/dp/B00EMMLF9C?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A27IF2C0XSS8DE
