Oh, is that so?
Itâs been ages since Iâve owned a S3 or remember what was required for the bw65/66.
Wished to jump on as if thatâs the case it is imperative to use TypeF if thatâs whatâs recommended and change it ASAP.
Anything else will burn the clutches.
Type F adds friction goop to create more positive/direct shifting and if recommended must be used.
Dexron et al. should never be substituted from all i had researched on the subject and ppl spoken with, as it will create less positive shifts and slippingâŚetc.
Earlier BW boxes call for TypeF too so no surprise.
It was a very solid consensus by those in the know.
I wouldnât play around or accept any other differences in opinion.
On an unrelated note, if wanting to drag race, donât rev within N or P and drop it into D!
There is some pin that blows out on the BW65/66 ⌠apparently common issue.
Replaced mine w Johnâs Cars conversion using th350 after that! A lifetime agoâŚ
Your screeching issue I never knew.
If I were you, Iâd pump it all out using the oil cooler line at the front of car, but thatâs me.
A couple quarts or so at a time, shut car off, replenish, repeatâŚthen drop pan, etc.
Changing pan fluid alone does not get all the fluid out as you should well know.
The bw65/66 is a rather fragile gearbox unlike earlier iterations, with reputation as a âslush boxâ as it isâŚ
One wants to do everything possible to encourage positive shift points.
I wouldnât play around.
If it calls for TypeF, use TypeFâŚ
