What would be the ideal replacement auto trans. for a
78 xj6 ser.2 with some improvements ?
Would adjustments of the trans. bands be required after
130K miles ? Never had it done so far.
Band adjustment is nominally an ‘on condition’ adjustment, Walter, only
fluid changes are specified in the maintenance schedules…
If there are no shift anomalies, flaring or whatever, adjustments are not
necessary - but if(!) done correctly; adjusting bands will cause no harm,
and may not be out of order…
Frank
xj6 85 Sov Europe (UK/NZ)-----Original Message-----
Sent: Friday, May 17, 2013 9:58 AM
To: xj@jag-lovers.org
Subject: [xj] 78 XJ6 ser.2
In reply to a message from Frank Andersen sent Fri 17 May 2013:
Frank!
Thank you for your input.
Like they say, NO problems leave it be.
Walter--
In reply to a message from W. Schuster sent Fri 17 May 2013:
Hi there,
If you have a 3.07/1 or 2.8 etc diff the o/drive
is unnecessary if not used for regular long trips.
The 350 is a good box and can be upgraded up to
2x the power that you would be using at the present.
I would not hesitate to use a well prepared std 350
for what you want for the next few years. Haroldus.–
The only transmission upgrade I recall is the John’s Cars
