My cars temperature control has gone crazy. Selected to 65 it puts out max
cold for a minute and then switches to max heat. It continues to cycle back
and forth.
I have seen similar problems posted in the archives but not a solution. Is
this common? does anyone know what part of the system I should give my
attention to.
puts out max
to cycle back
and forth.
solution. Is
should give my
attention to.
My cars temperature control has gone crazy. Selected to 65 it > puts out
max > cold for a minute and then switches to max heat. It continues > to
cycle back > and forth. > I have seen similar problems posted in the
archives but not a > solution. Is > this common? does anyone know what part
of the system I > should give my > attention to.
I’d suggest first going in and unplugging and replugging all the
electrical connections related to the system, just to be sure of the
contacts.–
Alex
79xj6L SII
86xj6 SIII
61 Sprite MkII
Menlo Park, Calif.
There are only two connectors that matter in this case. And since I have
already replaced seven amplifiers so far this year for the cycling back &
forth problem I’d say it is a damn good guess here. And yes they were all
different cars :-)!
out
to
part
