The side moulding on the driver’s side rear door of my 87 XJ6 is
missing the rubber insert. Where can I eitehr buy the insert or a
single piece of replacement moulding?
Thanks
BOB–
Robert_Hill
Fayetteville, TN, United States
Bob: these are not Jaguar parts (there was no side molding from the
factory), so the best bet is to find a trim shop that will be able to supply
a substitute.
Gregory----- Original Message -----
To: xj@jag-lovers.org
Sent: Tuesday, January 27, 2004 4:54 PM
Subject: [xj] 87 XJ door moulding
: The side moulding on the driver’s side rear door of my 87 XJ6 is
: missing the rubber insert. Where can I eitehr buy the insert or a
: single piece of replacement moulding?
: Thanks
: BOB
: Robert_Hill
: Fayetteville, TN, United States
Bob, is this the type of moulding with a vinyl strip inserted into an
extruded aluminum channel that is riveted to the body? If so, this was a
common type of aftermarket moulding popular in the 70’s-80’s. A bit hard to
find now. Ask around at some body shops and.or car dealerships…most do
business with a mobile “trim guy” who does mouldings, pinstripes, vinyl
repair etc. One of these guy oughta be able to fix you up.
If you like browsing Eaby there’s a guy who sells it fairly frequently…
Good luck,
Doug Dwyer
Longview, Washington USA
1987 Ser III XJ6
1988 XJS V12From: “Robert_Hill” dodgeshelby@cafes.net
In reply to a message from Robert_Hill sent Wed 28 Jan 2004:
Bob, this stuff is easy to find, try the auto paint & body SUPPLY
type places, that’s where you’ll get the best price. It comes on
rolls and you buy it by the foot. Here is a couple of tips: don’t
cut the piece to length until you are finished putting it into the
metal holder. Warm the plastic in a pot or coffee can of hot water,
it goes in Much easier. Use a small 'pocket type slot screwdriver
to push in the lso, as you are putting it in DO NOT Streach it,
thinking it will go in easier. While it Will go in easier, it will
then ‘shrink down’ in the hours/days after you have finished the
project. This stuff shrinks on its own over time/exposure to
sun/etc. The less you strech it-the better I seem to remember
you’ll spend maybe $20-30 to do a car (plastic only-no metal) Good
Luck–
'76xj6 (400/400) - '72xj6(parts car) - '70xj6 (350/350)
lancaster,ca, United States
In reply to a message from Gary Boehm sent Wed 28 Jan 2004:
Thanks to all for the info and advice. I am repainting the car and
have decided to remove the trim and fill the rivets holes since it
was not a factory item anyway. I liek the looks of a smooth door
so I will be happy and it will be the way it left the factory.
Thanks again
BOB–
Robert_Hill
Bob,
That’s a great idea. Fortunately my Jag never got the
side moulding put on it by the previous owner. I think it
looks better. Of course you have to be careful where you
park. It seems to me though that if I park 50 yards away
from the nearest car and go in a shop for 5 minutes some
ignorant moron has decided to park next to my car. Must be
Jag-envy !
Jim Legge
'85 SIII
'96 Disco–
Thanks again
BOB
James Legge
Washington, DC, United States
That's a great idea. Fortunately my Jag never got the
Jag-envy !
Trust me Jim, the presence of the door moulding doesn’t make you immune
from dings. The great variation in the shapes of doors and vehicle
heights means that chances are pretty good that any car next will be
able to hit you somewhere other than the strip. So I decided long ago
that the strips would go away when I do a repaint.===================================================
