What is the thick Black hose that comes out of the firewall … about 2 inches out …
then bends down 3 or 4 inches … then ends (sealed end) nothing attaches to it?
It’s on the drivers side.
What’s it called … and does anyone know who sells this part?
Bumped it while removing my heater valve, and a big piece of it fell off … it’s toast.
I think I can put a piece of duct tape over it until I get a new one.
That’s the duckbill hose. There’s one on the passenger side, too.
The duckbill hoses allow path for water to drain out of the air intake
plenum. The ends are not actually sealed. Water can drain out but engine
fumes cannot be sucked it.
Doug Dwyer
Longview Washington USA
1995 XJRFrom: “steve smith” scohog@aol.com
inches out …
to it?
In reply to a message from steve smith sent Sun 28 Mar 2010:
steve!
Those are water drainage hoses, xk s sells them. If you don’t
have a catalog, I can look up the part numbers.
There is one on each side of the engine coming out the firewall.
I need some new ones too.
Walter–
In reply to a message from Bruce Hugo sent Sun 28 Mar 2010:
Also called cowl drain elbows. I just had to get two new ones
from XKs after a bout with mice/rats in my garage. They ate
the bait I put out which then made them thirsty. They found a
perfect water fountain at the end of the drain and had a feast
on the hoses at the same time. It takes two parts- the Elbow
(BD-42707) and the Cap (BD-34737)
Kim–
In reply to a message from W. Schuster sent Sun 28 Mar 2010:
Walter, we’re both right! The drain is listed as a 2-piece
part; the angle tube and the drain tip. The numbers you
list are for the angle tube which has a different number for
right and left side. The part number I cited is for the
crimped tip which fits both.–
My xj s parts book has a # of BD42707 for the right side, and
JA-BAC1291 left side and is no longer available.
I believe the part number is BD 34737 - Drain Tube.
The rubber thingy on the right side has a connection for a port on the
battery enclosure. If your enclosure is gone, then get two sets of the left
side pieces. I got mine from SNG Barratt.
Gene McGough
XJ6C II 1976
XK-150 FHC S834515DN----- Original Message -----
Bruce!
Walter
Walter Schuster 78XJ6 FI Ser.II
Albuquerque/New Mexico, United States
In reply to a message from Gene McGough sent Sun 28 Mar 2010:
Those are really slick one way valves, sometimes, referred to as
gaithers. They resemble the mitral valves in human hearts.
Mine are still healthy!!! sorry, I couldn’t resist!!
Carl–
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
When ordering, Steve; refer to ‘right’ or ‘left’ side - Jaguars are
produced ambidexterous…
Yes on the right side for LHD cars. Now if anybody has a
source for that exact one with three openings, please let us
know. The single elbow is quite easy to find, the two headed
one bottom one is another story.
The ‘‘mitral’’ valve is held with … staples… great piece
of advanced engineering…–
