[xj] Air Filter Installation - 1986 XJ6
Hey,
I’m new to both this car and car repair/maintenance in
general and I was wondering if anyone could provide me with
some simple steps to follow to change my air filter. I have
already purchased a compatible filter but just would like
help from a veteran in its installation. Thanks–
johntheempire[at]gmail.com
John (is that correct? We use our real names here):
Replacing the xj6 Series III filter is simplicity itself and is really
self-evident. At the front of the air filter canister you will see the
clips that hold the front portion (which includes the air intake horn)
in place. Remove this and slide it forward; the canister itself can be
removed from its mount and its connection to the air flow meter behind
it by simply loosening the screw clamp. Pull it out, remove the old
filter, clean the canister, fit the new filter, and replace everything
in the reverse order. There is really nothing complicated and nothing
you can break. Make sure that the canister is seated fully in the rubber
tube which joins it to the air flow meter, and that the clamp is
retightened properly. That’s it!
Now oil changes: almost as easy! Have you read Jagcare III yet? If not,
please access it from the main J-L webpage, at the bottom under “our XJ
books”. It will tell you much that you will want to know.
Gregory
Victoria, Canada.
1966 Mark 2 3.8
1992 Series III V12 Vanden Plas
2002 X-Type-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org] On Behalf
Of Once-Ler
Sent: May 22, 2007 9:02 PM
To: xj@jag-lovers.org
Subject: [xj] Air Filter Installation - 1986 XJ6
Hey,
Welcome John! Steps:
  1. Identify the intake side of the engine and the big black can with silly
    little spigot sticking out its front.
  2. Undo the 3 finger clips at the front of the can and remove that faceplate
    assembly from the can.
  3. Remove the spigot from the faceplate and put it in your metal recycling bin
    for next pickup.
  4. Remove the small bolt in the front of the can that holds the filter via a
    conical steel seal.
  5. Pull out the old filter and replace with new.
  6. reverse step 4.
  7. You don’t need to reverse the other steps, because the engine sounds great
    without the silly spigot.
  8. If you want to do something really nice, go to a wrecker and find a Series
    II XJ6 and remove the whole can and bracket from it. Put that on your car!
    See pics 3 & 4 here…
http://www.jag-lovers.org/snaps/snap_view.php3?id=1149575752
Does your car have the two bolt holes in the fender for the SII bracket? Our
'86 did. Using the bracket reduces the load on the rubber isolators for the
AFM (flow meter).–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
Once-Ler wrote:
Hey,
In reply to a message from Cannara sent Wed 23 May 2007:
Careful Alex, some of us like quiet Jags ;)–
  1. You don’t need to reverse the other steps, because the engine sounds great
Dave W 85 XJ6 VDP ‘Black Beauty’ 157K - Getting closer !!
Lansdale, PA, United States
Just hold your right foot back a little Dave. Isn’t that what the PA State
Policeman told you?
Alex
86xj6 SIII (Black)
Menlo Park, Calif.
Careful Alex, some of us like quiet Jags :wink:
