Hi Don,
I had the same problem, except that my metal did not become bare and bright:
how did you do that? poured some bicarbonate of soda on it and scraped ?
I suggest it’s either a problem of the battery fan, or a problem in the
alternator regulator: it’s boiling up because the voltage delivered is too
high. Do you have a voltmeter on the dash? Check whether the battery is in
the red zone (too high). If it is, then you must reduce the voltage output
from the regulator (you can on the Lucas 20CR one which has the 4TR external
regulator): there’s a chpater on this in Haynes.
Put a voltmeter in parallel to the battery terminals. Rev up the engine: the
voltage should be approx. 13-14. Mine had been 16 (and boiling up) before I
renewed the alternator. However, I don;t know what you could do to reduce
the voltage on an internal regulator.
It’s not difficult at all
Good hunting
Guillaume-----Original Message-----
From: owner-xj@jag-lovers.org [mailto:owner-xj@jag-lovers.org]On Behalf
Of Don Lewis
Sent: Monday, October 01, 2001 3:28 AM
To: XJ Lovers Mailing List
Subject: [xj] Battery snorts white powder
Looking for some feedback from the technical buffs. My battery is
surrounded by a black steel box with a fan. I have recently noticed that
the battery is producing white powder on the top edge of the box where it is
in contact with the battery. It would rot your nose if you inhaled it!
Its water soluble and when cleaned off the metal is bare and bright.
What is causing this problem and how can I stop it before it becomes a major
problem (rust)? Should I add a rubber strip between the box and the battery
to insulate them from each other? I am planning on repainting the box and
wondered if I should get it powder coated to better protect it from the
battery. Any other ideas.
Thanks in advance.
Don Lewis
Jaguar XJC 5.3 1977
Melbourne, Australia
http://donscoupe.xjc.com.au
http://www.jag-lovers.org/cgi-bin/majordomo.
