Ok, I am looking forward to this project. I will be taking an 87 VDP
starter and putting it in my 73 jag, I have been told by Craig Talbot
that these are bolt in, but the PO of the starter (Jim, who kindly
gifted it to me), has suggested that there is some circuit or relay
that is built in on this starter that was a separate piece on older
models. Any one able to corroborate these statements?
Also, there is supposed to be a spacer for my starter, how do I tell
if it is missing or not, is it some gasket, or a metal fitting, or…?
William G Higgins
series 1 XJ6 4.2l
Vancouver, BC2009/12/6 cadjag carl.hutchins1@sbcglobal.net:
In reply to a message from kassaq sent Sun 6 Dec 2009:
I agree with Tom. And a very good narrative on how to do it.
I would add/emphasize as follows:
Disconnect the battery positive at the battery. Wrap the end
with an insualtor of sorts. An old glove will do.
Disconnect the red/white at the relay.
Disconnect the starter/solenoid cable at the stud on thne fire
wall.
Take out the top starter bolt from above.
Disconnect the lower bolt.
Pull the starter forward and down, cable and wire and remove to
the bench.
Now, you can bench test if desired. Connections can be cleaned
tightened much better here. You can apply battery power here as
previously mentioned to bench test.
Prep the replacement or repaired starter with the red/white wire
and cable.
It is easier to make the electrical connections at the cowl than
down in the bowels.
Removing the battery can give you a bit more elbow room above and
serve as a power source for bench testing the old critter.
If the replacement starter is not new or rebuilt, a bench test is
strongly recommended. If used, clean it up. I prefer to work on
clean things, it just seems to go better.
Report as you go, it will be a great source of satisfation to
become intimately acquainted with this region of your charge.
Carl
Like Frank says, the starter is fairly easily accessable for a
solitary person to remove and replace with little previous
experience. It is in fact, one of the better places to
start ‘cutting your teeth’ on your car. You will definitely want to
remove one of the battery cables from the battery before you begin.
Next, you will want to take off the two ‘wires’ that go to the
starter. One of them is the heavy cable that goes to the starter
solenoid, and the other is the smaller wire that also goes to the
solenoid. The top bolt for the starter is accessable from above,
and the lower bolt from below. There is a metal shim that you will
want to remove before you take your starter to get rebuilt. You
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
