They were Jaguar-branded units made by Alpine, as indeed were the very last
Series III units with remote CD stack (1992).
Gregory----- Original Message -----
To: xj@jag-lovers.org
Sent: Tuesday, October 07, 2003 3:54 PM
Subject: Re: [xj] Best " drop in" replacement radio CD player? '85 xj6, SIII
: In reply to a message from Dr Gregory Andrachuk sent Tue 7 Oct 2003:
: Now this might do! But alas, no late models (1990-ish) here in the
: States to pick from…Maybe I’ll look on ebay. Were those the
: Alpine branded units??
In reply to a message from Dr Gregory Andrachuk sent Wed 8 Oct 2003:
Hmmm. Would the 1992 model drop in? (only the Brits could have made
such a convoluted mess of all that mounting hardware!)–
Ted Macklin/'85 XJ6SIII
In reply to a message from TMack sent Wed 8 Oct 2003:
Hi
How do you make the antenna work if you don’t have the original
radio/cassette unit?
Thanks
Phil–
Phil Moseley
In reply to a message from Phil Moseley sent Fri 10 Oct 2003:
Phil:
I have installed several aftermarket radios in my Jags, and if
memory serves, they are all wired for power antennas. I’m not sure
if only the white wire controls the antenna power, or if there is
another, but that (those) would be connected to the appropriate
antenna wire(s) on the aftermarket unit. Perhaps others will chime
in.
Cheers–
Thanks
Phil
Yes, our SIII antenna/relay works fine with the one wire from the Sony I put
in (marked “ant”).–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
Phil:
in.
In reply to a message from Cannara sent Fri 10 Oct 2003:
Thought I’d add my two cents. I was recently turned on to the new
XFM (satellite) units and they appear to be relatively inexpensive
for the technology involved.
I’m drooling to install one of these.–
TonyP '84 XJ12 Vanden Plas
Vernon, British Columbia, Canada
