In reply to a message from Dr. Gregory Andrachuk sent Sat 14 Mar 2015:
Thank you for the reply. If it has to be 134A than so be it.
My concern was this might be one of those situations where the whole
dashboard has to come out at great expense which would certainly
effect my offer for the car. I just have no idea how much expense
to factor into the negotiation.
‘AC doesn’t work’ is pretty cryptic for AC cost assessment, Larrman…
Best case; 25 cents for a new fuse. Worst case; 3000+ dollars or thereabouts
for professional work and parts, changing everything - and that would be way
beyond what one would normally expect…!
You should really question the vendor, and if possible - do some simple
tests. A main point is to check whether or no the compressor engages; the
idle drops as the AC is turned ‘on’ - and that the fans operate. A standard
test is to set to ‘auto’ and turn the temp control to full cold, ‘65’. The
face vents should be open, footwell and rear vents should be closed - and
working properly; the face vents should blow cold. This confirms a well
working system. And with the car available there are other tests to clarify
if it is a simple ‘malfunction’, due to some specific component failure - or
indeed a just lack of refrigerant…
If vents work properly; the common fault is that the refrigerant has leaked
out, and/or seals have dried out - due to leak-out of refrigerant, or
non-use. While finding and elimination leaks may be a hassle, the procedure
is standard for any AC shop - though they may be chary on giving you a cost
estimate. However, if a conversion to 134A is in the cards it would
basically cover and eliminate such faults - with fairly predictable cost
estimates. Though not covering actual component failures - which must be
assessed separately…
In-dash operations are usually not required - the evaporator itself is
fairly robust. Vacuum line leaks inside the dash may cause operation
anomalies - but are seldom encountered. And honestly, best approached by the
owner - it’s simple, but very time consuming…
Your description of the car makes my mouth water - but be aware that regular
use, and maintenance, of a car is ‘best practice’ rather than a simple
mileage count…so…
Frank
xj6 85 Sov Europe (UK/NZ)-----Original Message-----
Sent: Sunday, March 15, 2015 7:16 AM
To: xj@jag-lovers.org
Subject: Re: [xj] Cost to Repair AC
