This was forwarded to me by a friend.>
Hey!! here’s a laugh or two …
This is an absolute classic!!! Read this
slowly…This
is a bricklayer’s accident report, which was
printed in the newsletter of the Australian
equivalent of the NZ Workers’ Compensation Board.
This is a true story. Had this guy
died, he’d have received a Darwin Award for sure…
Dear Sir
I am writing in response to your request for
additional
information in Block 3 of the accident report form.
I put “poor
planning” as the cause of >my accident. You asked
for a fuller explanation and I trust the following
details will be sufficient. I am a bricklayer by
trade. On the day of the accident, I was working
alone on the roof of a new six storey building. When
I completed my work, I found that I had some bricks
left over which, when >weighed later were found to
be slightly in excess of 500 lbs. Rather than carry
the bricks down by hand, I decided to lower them in
a barrel by using a pulley, which was attached to
the side of the building on the sixth floor.
Securing the rope at ground level, I went up to the
roof, swung the barrel out and loaded the bricks
into it. Then I went down nd untied the rope,
holding it tightly to ensure a slow descent of the
bricks. You will note in Block 11 of the accident
report form that I weigh 135lbs. Due to my surprise
at being jerked off the ground so suddenly, I lost
my presence of mind and forgot to let go of the
rope. Needless to say, I proceeded at a rapid rate
up the side of the building. In the vicinity of the
third floor, I met the barrel which was now
proceeding downward at an equally impressive speed.
This
explained the fractured skull, minor abrasions and
the broken
collarbone, as listed in section 3 of the accident
report
form. Slowed only slightly, I continued my rapid
ascent, not
stopping until the fingers of my right hand were two
knuckles deep into the pulley. Fortunately by this
time I had regained my presence of mind and was able
to hold tightly to the rope, in spite of the
excruciating pain I was now beginning to experience.
At approximately the same time, however, the barrel
of bricks hit the ground and the bottom fell out of
the barrel. Now devoid of the weight of the bricks,
that barrel weighed approximately 50 lbs. I refer
you again to my
weight.
As you can imagine, I began a rapid descent, down
third floor, I met thebarrel coming up. This
accounts for the two fractured ankles, broken
tooth and several lacerations of my legs and lower
body. Here my luck began to change slightly. The
encounter with the
barrel seemed to slow me enough to lessen my
injuries when >I fell into the pile of bricks and
fortunately only three
vertebrae were cracked. I am sorry to report,
however, as I lay there on the pile of bricks, in
pain, unable to move, I again lost my composure and
presence of mind and let go of the rope and I lay
there watching the empty barrel begin its journey
back down onto me. This explains the two broken
legs. I hope this answers your inquiry.Dave
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
MZ�
FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/xjfaq.html
