In reply to a message from Daniel Davis sent Sun 15 Nov 2015:
Dan,
The lock solenoids are activated only from the drivers lock.
The doors should lock and unlock from the inside and the
outside regardless of how they got locked or unlocked…
One of the checks described is that there is a fault present if the door
fails to open with the ‘flap’ in the ‘unlocked’ position, Aristides -
implying that it is normal for the door not to open with the ‘flap’ in the
locked position…
He doesn’t positively state that he unlocked the ‘flap’ - frankly; I never
tried out that particular aspect of door lock operation. However, is the
‘flap’ is in the lock position; the door will not open from the outside.
As for his problems with the driver’s door lock, he may be under a
misunderstanding. If the driver’s door unlocks it is by the door key only -
there is no solenoid/motor on the driver’s door.
You are of course right, if there is a fault with the locking - it likely
some rod faults, and the door trim must be removed to assess the problem.
But removing the inside door trim with the door closed is ‘difficult’, he
should try ‘fishing’ the door open - a car thief would do it in a sec…
Frank
You could probably take the door side cover off even with
the door closed. Then you could reach the lock and open your
door.
You should check both doors… maybe start with the
passenger one, which I presume you can still open, and this
will give you also the pointers for your slim jim.
The original message included these comments:-----Original Message-----
Sent: Wednesday, November 18, 2015 10:38 PM
To: xj@jag-lovers.org
Subject: Re: [xj] Driver’s door stuck - can’t open from inside or out
I was fiddling with the passenger’s side door, and found
that once I locked that from the inside, I couldn’t open
that either.
Had to climb into the back seat, get out that door, then
open the passenger door with the key from the outside.
I think I see why the driver’s door won’t open. If, like the
passenger side, it won’t unlock from the inside, and can
only be unlocked manually from the outside, then I’m out of
luck on the drivers side, as the key has never really
engaged the driver’s side lock manually at all, and would
only trigger the solenoids to unlock the doors.
