I recently organized and ran a San Diego Jaguar Club event at a local
performance shop that has a dynamometer. We had 11 cars including a 1956
Ford Thunderbird, a 1984 Ferrari and 9 Jaguars including my 1969 E-Type and
1984 XJ6 VdP. Both of my cars are equipped with their original matching
numbers 4.2L XK engines. These cars of course are very different even
though the engines have the same displacement: the compression ratios are
different, the E-Type has dual Zenith Stromberg while the XJ6 VdP is EFI
equipped, the E-Type has a stock manual 4 speed while the VdP has the BW66
automatic transmission and the VdP has a lot of emissions control equipment
(AIR pump, catalytic converters, vacuum systems, etc).
In my opinion both of these cars were running good that day although the
E-Type was running particularly well. Here are the numbers as they were
run on the dyno up to red line (5,000 RPM):
1984 XJ6 VdP, 4.2L EFI,
Max Horsepower STD 100.2
Max Torque STD 152.3 ft-lbs
Speeds shown on the chart (while in 2nd gear, automatic transmission)
57-88.4 MPH
Air/Fuel Ratio held pretty constant from 3,200-5,000 RPM and ranged from
13.2 to 11.5
I removed and replaced this cylinder head a few years ago for a burnt #1
exhaust valve. I recently did a compression check. I thought the engine
was running OK but not great, and this shop agreed. This is a stock engine
with 145K miles on it. The torque was 152.3 ft-lbs at about 3,200 RPMs,
dropped off in a linear fashion all the way to red line where it ended up at
about 80 ft-lbs at red line. The HP was about 95 at 3,200 RPMs and then
increased slightly up until maximum (100.2) at 3,800 RPMs where it decreased
until 80 HP at red line. This verified what I feel in the car as much less
acceleration than the E-Type and a distinct lack of torque/HP approaching
redline. The owner and technicians said this engine was pinging and
recommended that I look at the timing and consider retarding the timing a
bit. I usually use 91 octane during the summer months to minimize pinging
under loads.
Here is the comparison numbers from my E-Type
1969 E-Type
Max Horsepower STD 149.1
Max Torque STD 207.2 ft-lbs
Speeds shown on the chart (while in 4th gear) 40-101.2 MPH
Air/Fuel Ratio held pretty constant from 2,000-5,000 RPM and ranged from
12.6 to 13.5
I recently did a valve clearance check (they were good), compression check
(good strong numbers), replaced the plugs, points, rotor, cap, condenser and
wires. I thought the engine was running very good and this shop agreed.
This is a stock engine with at least 80K miles on it (but probably a lot
more). The torque at the low end jumped right up to 200 ft-lbs at about
2,200 RPMs, peaked at 3,000 RPMs started to drop off at 3,600 RPMs and then
ended up at 150 ft-lbs at red line. The HP was linear starting at 70 HP at
about 2,000 RPMs and increased to just shy of 1150 HP up until about 4,200
RPMs where it held pretty much constant until red line. This verified what
I feel in the car as a lot of low end torque, very smooth and spirited
acceleration to red line in either 2nd, 3rd and 4th gear when I try that.
The owner and technicians said this engine was running really well,
particularly the ZSs and they recommended that I “DON’T TOUCH A THING”.
I am interested in an assessment of these two stock engines and how they
compare to other stock XK engines that have been run on a dyno. I guess I
didn’t expect to see such a big difference in the HP and torque numbers, but
this is the first time I have run any of my cars on a dyno and didn’t know
what to expect. I did this because I have read a wide range of numbers for
HP and torque for these cars in various books and marketing brochures and
wondered what the real numbers were. Now I know. I am still working on the
V-12 in my wife’s 1990 XJ-S and plan to run that on the dyno as soon as I
get it back on the road again later this month.
I can scan the charts and put them on Jag Lovers if anyone is interested in
seeing the plots.
Paul M. Novak
1990 XJ-S Classic Collection convertible
1984 XJ6 Vanden Plas
1969 E-Type Fixed Head Coupe
1957 MK VIII Saloon
Ramona, CA
@Paul_M_Novak1===================================================
