[xj] Engine leaking oil?
“Jean G. Catford” <@Jean-Guy_Catford>
Recently an oil leak appered on the rear of the engine. At stop
loght it smeels oil and not clear if it is the head or valves cover or …
The head is suspected but I am not sure, is it a frequent problem with this
engine.
Thank you all.
J.G.Catford
1986-JAG. XJ6
1973-MGB-GT
1975-TRIUMPH TR6
1960-MGA Coup�
1989-Ford Aerostar===================================================
To remove yourself from this list, go to http://www.jag-lovers.org/cgi-bin/majordomo
“DOUGLAS DWYER” <@Doug_Dwyer>
Jean,
If the leaks seem to be originating up high, I would suspect the “half-moon”
seals at the rear of the cams covers and/or the two oil feed pipes at the
rear of the cylinder head. Replacing the half-moon seals is a cake-walk and
I’d imagine that the oil pipes might only need a little snugging up.
If the leak seems to be in the nether regions it could well be the rear main
seal. Although I’ve never replaced one on a jag I’ve heard that it is quite
the job…hard enough that you’d really have to ask yourself just how badly
you want it fixed.
Doug Dwyer
Longview, Washington USA
this----- Original Message -----
engine.
