after a longish run in 30 degree heat when I stopped at
the first stop sign in town so did the car. Turns over but
does not attempt to start. Open the bonnet and the is
quite high heat from the engine bay although the
temperature gauge was only reading less than 90. Pour a
small bottle of water over the fuel injection rail and it
starts immediately, but runs rough for a while. This
happened some time back and on advice I replaced the fuel
pump as low fuel pressure was suspected. If the fuel is
circulating back to the tank via the return line why is
the fuel getting that hot that it vaporises? 1983 XJ6 vpâ
Col
âPosted using Jag-lovers JagFORUM [forums.jag-lovers.org]â
The archives and FAQ will answer many queries on the XJ seriesâŚ
