[xj] GM400 TRANSMISSION KICKDOWN SOLENOID
Wonder if anyone can please help, I have to go tomorrow to fetch a
solenoid for the above and dont know what it looks like, im just
afraid to buy the wrong thing, or maybe there is just one solenoid
in that gearbox then I cant go wrong ? Any input is appreciated.–
hebe
In reply to a message from hebe sent Mon 28 Sep 2009:
Hebe:
Try Rockauto on line, it may have a picture. probably a good price
as well. No affiliation, just helpful folks!
Carl–
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
DO you not also have the switch on the pedal?
The TH400 gets its electric signal from a switch mounted on the accelerator to a switch mounted on the drivers side of the transmission.
Make sure the switch is adjusted properly before resorting
to replacing parts that are not needed.
On all the TH400 I have ever seen I have never seen the
switch on the trans go bad. It would either be the switch on
the pedal, that had gone bad or was just out of adjustment.
I used to work on many, MANY big block GM vehicles.
Just thought I would mention the adjustment if it has not
been done or though of already.–
hebe
Tom Truett '85xj6, ex-diplomat, no resonators, gettin faster
Panama City, Panama
In reply to a message from Race Ready sent Tue 29 Sep 2009:
Thanks to this thread I’ve just been out, checked my kickdown
switch, adjusted it and then had the acceleration experience of a
lifetime.
When the V12 holds on to 1st and 2nd to almost 6000 rpm it’s quite
a beast, isn’t it? (I actually chickened out at 5000 rpm in 2 -
even going up quite a prolonged hill we were getting a bit quick
for a nightime driving.)–
al mclean '93 XJS 4.0 - '84 4.2 Daimler - '84 DD6
Telford, United Kingdom
In reply to a message from almcl sent Wed 30 Sep 2009:
It sure is a beast !!!
I have put also a manual switch and I can activate the
kickdown switch at will… It’s sooooo much fun !
Aristides–
Aristides Balanos, 1986 XJ V12,VDP - www.e-psychi.com/jaguar
Montreal, QC, Canada
