[xj] help request
Hi All
I am new to Jaguar ownership, I was given a 1986 XJ6 and it will
not start. I have good clean gas and the engin will turn over. No
spark is my current problem. When I test the coil no pulse light or
constant light yet when I attach the test light to the negative
post on the battery and then test both sides of the coil I get a
strong constant light. Any help would be greatly appreciated.–
stinker
Welcome stinky, smelly, or whatever – we need a real name here!
Does the light flicker when you run it from + batt to - coil and crank?–
Alex
79xj6L SII (BRG + wires)
86xj6 SIII (Black)
61 Sprite MkII (Red)
Menlo Park, Calif.
stinker wrote:
Hi All
stinker
In reply to a message from Cannara sent Sat 12 Aug 2006:
Sorry about the name thing, No flicker from the test light when
connected to the pos post of the battery then to the coil when
cranking
Jim
Wynantskill, New York–
stinker
cranking
Connect the test light (3 - 5W) between coil neg and ground, Jim, and
retry…
Frank
xj6 85 Sov Europe (UK/NZ)===================================================
